Hi
I have these (with 'just' a NAD C326Bee) My advice: buy the Tannoy's!
If you rather don't like to compare hifi equipment (I don't): buy the Tannoy's! ;-)
My
personal experience:
The dc6t's are wonderfully balanced, have lot's of enthousiasm. For me, they hit the sweet spot. Very easy to drive too, you really do not need
an expensive amp. Mid range is superb: voices are perfectly rendered.
They are maybe best with 'high quality' acoustic music, pure instruments and voices.... But handle dance, rock, pop... just as well.
Regarding to placement, they aren't picky. The manual tells to put them at least 50cm from the wall, but to adjust to own findings.
My findings:
- 10cm from wall gives a little bit more bass without becoming bothersome or boomy.
- 50cm from wall gives a little less bass and a more airy soundstage.
For me the sweet spot is 20 à 30 cm, a little more direct sound and full but thight lowrange (slight emphasis on bass)
Make sure to avoid resonances when placing them at a certain distance to the wall.
(But if you'd rather listen to equipment than music then my advice woud be; don't buy them, one will keep changin' equipment and never get
to the music itself. Here's a piece on the gear aqcuisition syndrome. It's about photography but one can apply it to hifi just as well:
http://www.f-stopeight.com/the-self-talk-retorts-of-an-ex-gear-addict-how-i-started-breaking-free-from-gas/)
@Alpne: try connecting your ipod directly on the amp (or on a cheaper one), it will sound less harsh.
Good luck.
