System upgrade advice please!!
Tone60
I currently have the old Marantz pm4400 series amp. and matching CD player hooked up to Mission m71i speakers, and the Rega RP1 performance pack turntable. I don't really have more than an entry level budget, but would like to upgrade to a noticeable difference. With what do people think I should start my upgrade?
Ok, maybe I should be more specific. I can only really afford to update rather than upgrade presently. I feel the sound is OK, but lacks depth and warmth. Does anyone think there would be a noticable improvement if I update to the marantz 6005 amp? Speakers I am considering are either DALI Zenzsor 3 or Montor audio Bronze 2, but again, will there be a noticeable enough improvement in sound?
I dont think there will be much of an upgrade changing the amp.
Speakers may make the difference. Just make sure they are efficient
I would change the speakers and the cd player also
Dali Zensor 3 or Quad 11L 2 classic speakers
Nad 516 BEE cd player or Marantz CD 5005 cd player or Onkyo C 7030 cd player
I'll go with the speakers first then. Was thinking g the Dali Zensor 3 would be an affordable change, but will Investigate others too. I want there to be a noticeable improvement, so may have to save up first.I prefer the sound through my old Celestion F30 floor standers from another room that are part of my surround sound for the TV, but I don't have the space for floor standers in this room .
