Synology + Dac????
Hi all,
I have a Synology Ds211 and hope to attatch a Beresford dac can anyone through any light on wether or not the Synology will recognize a usb dac or wether the Synology audio remote must be used to plug the dac into??? The synology web site isnt that clear on the matter! :doh:
Regards,
Oozle
Thanks big boss, i had seen this list but its unclear if these devices were connected via the Synology audio remote device or directly to the drive itself.
oozle
I have a synology ds710+ connected to a Cambridge Audio dac magic plus via USB , works perfectly.
to control the music I use the ds audio app installed on my Idevices and android stuff , there is a remote mode avalaible in the app.
regards
same question about DACs. I plan to buy an Audiolab M-DAC. Not sure if it works. I mean connect with DAC using USB
