|( Help!!!
Following on from Chisy's thread I have also purchased a DS212j NAS and 2x 2TB HDs.
HDs installed = check
Synology software installed = check
Volumes created = check
I then thought it best to copy across all my music (via my iTunes folder) and photos to the NAS (volume 1). I set up two files within the NAS - 'Music' and 'Photos' (for obvious reasons!).
This transfer, via wifi, has just finished and I was hoping to get the drive up and running fairly easily. The User Guide tells you to just open up 'Media Server', 'iTunes', 'Audio Station' and 'Photo Station' and basically enable each one.
This, in theory, should enable me to use the NAS as intended - so I can see it as a shared device within iTunes, play music via Audio Station and also see photos via Photo Station.
Problem is, neither 'Media Server' or 'iTunes' will stay 'enabled'. If I tick the boxes and click 'OK' the NAS saves the settings (supposedly) and then unclicks them. So I'm left with wondering whether either options have been enabled.
To make matters worse if I open Audio Station I can not see ANY of my music files which I've spent 2 days transferring across!
If I try to open Photo Station, a new browser window opens up with the following:
"SQLSTATE[08006] [7] could not connect to server: No such file or directory Is the server running locally and accepting connections on Unix domain socket "/tmp/.s.PGSQL.5432"?"
Any ideas what is going on? I'm slowly going mad!!!!!
PJ
PJ
