Subwoofer
Morningken
Hi guys
im thinking of replacing my faulty QA sub with a BK xls200, the problem is i dont really understand the connector on the BK sub, at the minute my faulty sub is connected via a QED sub lead to my denon arv 1920 av amp, can I connect the BK sub with the same lead.
many thanks
jonathanRD
179
52
18,670
The BK subs come supplied with both high and low level cables.
The low level cable (like a single RCA) will connect into the back of your Denon using one of the subwoofer pre-out connections.
Having a quick search, I couldn't find a image or the manual for the 1920, but to be sure just check you manual, I assume you have one standard sub woofer pre-out. If so the BK low level cable will connect to it.
spiny norman
293
Morningken said:
So the sub out on the amp I would put the sub lead into that and run it to the R or L on to the bk sub right
No, just to the right input on the sub, which is labelled 'Right (Mono)' or something similar, and is designed for just such a connection.
