- Aug 10, 2019
- 2,556
- 4
- 0
Have an MJ Acoustics Pro 50, not a Mk11. Would like to connect using both high and low level connections. Do not have the user manual anymore so consulted the MJ website and found the following; "If you are going to connect both high level & LFE inputs at the same time please make sure that your Stereo or AV amplifier does not have a ‘Digital Output Stage’ or is wired in ‘BTL’ (Bridge Tied Load) mode." The MJ is connected to an Onkyo TX-SR606 with Mission 753(which are very light on bass) at the front an AE centre and Mission m74 rears. The main question is; Is it safe to connect both High and Low level on the MJ to the Onkyo?
