sub for atc sc 11s
The obvious choice would be the ATC C1 subwoofer if you want to keep the same tight, controlled, and clean bass that the SCM11's produce. Do you have a budget you're sticking to?
nokz:ok so im running my ATCsc11S THROUGH AN ASTINTREW AMP WHATS THE BEST SUB FOR THESE SPEAKERS
Hi nokz
I have already recommended the C1 sub to you in the Home Cinema section. In case you are not aware there is also currently a similar thread in the Home Cinema section (started by AlmaataKZ) which you also might find useful
http://community.whathifi.com/forums/t/430034.aspx
All the best
Rick @ Musicraft
