Streaming Craps Out
FahadAhmed
I took the old laptop out from underneath the bed and plugged it into my amp just to stream some FLAC. Now at high (well not so high, 50% of the amp's limit, cause i live in an apartment), the music starts breaking a little; the way a cheap speaker would sound if you increase the volume. The CD player and the turntable don't show any such symptom. Could it be the quality of the FLACs or the quality of the external creative sound card I am using? Will a DAC solve the problem?
tomlinscote
30
Maybe you are overloading the amps input circuit using to high an output volume from the laptop, try turning the laptop volume down and see if that helps as it sounds like you are getting clipping.
On a lower volume setting is the speakler ouput louder with the laptop compared to the other sources?
T
