To start with Hello!
I have at the moment as my main system Roksan K2 Amp, Cyrus CD Transport, MA Silver 2's & Arcam IR DAC - I've ripped (in progress) most of my CD collection to .flac which I listen to on my second budget system coupled to my PC & on the main system via a DELL lappy - I listen to Spotify on both systems, on the main system via my TV using optical (not ideal) out & on my PC system using the desktop client & AIMP player for .flac.
At the moment I have a Homeplug system which gives Ethernet at the Hi-fi & throughout the house & I use the desk PC as my source as it's on 24/7 & have 4 TB of space - At the moment to play .flac through my main system I’m using a lappy connected to the DAC again not ideal as i have to keep getting up & the lappy is really in the way + I have other uses for it.
My question is: - As I have a half decent DAC on my main system & music available to it via Ethernet I just need a simple streamer to use with my main system, that can play .flac (mainly ripped from from Cd's not hi-res) & ideally Spotify. I wont be moving from 2 channel & the streamer needs Ethernet in & either Coax/Optical out - I don't need a streamer with a DAC or anything fancy, as I'm coming to the conclusion a streamer really just passes the bit perfect Ethernet on to the DAC? (am I wrong here?)
Any ideas? I've looked on the Sonos site but a bit confused as I don't need multi-room or wireless just the ability to play music streamed from my PC in another room onto my Hi-Fi in the lounge - I can't tell any difference between music streamed to my laptop through my lounge system against the Cyrus CD transport (well I can't hear any) Any ideas? I have 2 iPads & an Android tablet if required for use with the streamer - Sorry for rambling post .
