- What is the maximum temperature and humidity allowed for long-term storage of these IEMs without degradation of the diaphragm and dual magnetic dynamic driver? here home is varies 34-36C 59-70% i have kz edx pro e edc pro?
I guess you will be able to tell us.....
Does your ears heat up like the Sheffield industrial furnace plant? 🤔
I would think you will be lucky to find anything that is designed to work long term in those con so not surprised you got no response from engineers.I didn't know that IEMs were so fragile to humidity. I have the KZ EDX Pro and the KZ EDC Pro and here the humidity is high, ranging from 60-71% to 34-36C.
I didn't get any response from KZ engineers about the temperature and humidity range for long-term storage of IEMs (EDX Pro and EDC Pro) and within that range not to damage, degrade the dual magnetic dynamic drivers and oxidize.
You may have better luck checking out the water proof earphones 😀I didn't know that IEMs were so fragile to humidity. I have the KZ EDX Pro and the KZ EDC Pro and here the humidity is high, ranging from 60-71% to 34-36C.
Do they work in those sort of temperatures?You may have better luck checking out the water proof earphones 😀
I just found this on AliExpress:
£27.05 | 20 Hours Play time Swimming Waterproof Bluetooth Earphone Dual Wear Style Sport Wireless Headset TWS Ipx7 Earbuds Stereo
20 Stunden Spielzeit, wasserdicht, Bluetooth-Kopfhörer, Dual-Wear-Stil, Sport-Wireless-Headset, TWS, IPX7, Stereo-Ohrhörer - AliExpress 44
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
