Squeezebox Question
I have a Squeezebox 3 connected wirelessly to my laptop to an external drive where I store all my music with a digital cable straight in to my Supernait which works brilliantly.
The question is how do I set my Squeezebox to play music from the laptop ie spotify or dvd drive, I know it should be simple but I can't get it to play from the laptop only from the laptops external drive, hope you can help cos its driving me nuts
Hm - I thought Squeezebox could basically play served files or internet radio, and that's it - didn't think there was an option to stream whatever the PC is playing via it's own internal audio … la Airfoil. But I shall investigate...
I don't think spotify can be played (Yet) but there was a workaround mentioned on the slimdevices forum. I heard that spotify would be officially supported shortly but when is anyone's guess.
