Speakers to sit on a shelf very close to back wall
Not sure what happened there.....budget is a grans, DAC is MHDT Havana, Amp is Moon i.1
WishTree
107
matthewpiano said:
Spendor S3/5r2, as long as your amp can drive them OK. The sealed enclosure and balanced sound should work very well. I'd suggest an audition though to make sure the Moon is up to the task.
Hi.. what is the difference between S3/5R and S3/5R2?
Hi campbell1968
I'll recommend ATC's SCM11 monitors. SCM11 monitors closed box design and importantly their flat and honest presentation helps position them close to walls without the LF in particular getting itself into a twist. Fwiw, I've got clients who are also happily using ATC passive monitors with Moon amplification.
http://www.atcloudspeakers.co.uk/scm11.php
All the best
Rick @ Musicraft
