Speakers on top of a Sky HD box?
Hey
Would my centre affect the sky box?
It is shielded, but dont want to leave it there when the sky guy comes tomorrow.
I like the way it looks there, but can move if this might be an issue with the internals.
It's not so much the magnetic problem rather than the vibrations that you will be sending to the hard disk contained within.
I wouldn't heartily recommend that you put anything on top of the Sky HD box.
I used to keep my centre speaker from my kef3005se speaker package on top of my sky box.
I am not sure if this contibuted to the 7 sky boxes i had in 8 months but every one out the 7 had problems with from hard drive freezing to rewind fastfoward issues.
When i had my 8th box the amstrad i took the centre speaker off the sky box and since then the last 9 months i have had no problems at all.
I would personally not recommend it at all.
Since it looked so good and it was the best place to keep my centre i now have it on top of my dvd recorder this also has a 250gb hard drive but it has not affected it any way whatsoever.
You may want to try this or use another item to put the centre speaker on top off if this option is available for you.
By the way i have a SKY + HD BOX.
Hope this has helped.
