Speaker Upgrade
I am looking to upgrade my Infinity Oreus 5.1 package and dont know which package go for, I like the clarity of the Oreus but would like a fuller sound
I have considered the Q Acustics 2000 package but I'm not sure if this would be a good move or not, I have found a brand new set of Roth Oli 5.1 for £300 or do I need to spend more to get a decent upgrade in quality.
I cannnot have large speakers due to the size of my room
My amp is a Harmon Kardon AVR 255( I like it dont groan Pls)
Every different shop i go to says a different package would be best and by the blank looks I get I'm not sure they even know what the Infinty package is.
Any advice would be appreciated
The Dodge
Ronald Archiebald
63
The Dodge,
Why don't you take your HK amp along and demo it with your speaker choices and decide what sounds best to you?
Have you also considered the QA 1010i 5.1 system, available for £250 from Richer Sounds? I've owned this and it's a good package for the money - probably also within your budget.
Ronald
The Dodge,
Im in the market for a new 5.1 package too and auditioned the QA 2000. The system was hooked upto a pioneer and they sounded amazing. Yet i've heard of them sounding bright from other people. Whats your budget?
Sorry i should have put on that my budget is £600-800 and I am looking for a small conventional speaker package rather than a sub sat set up.
