Speaker Cables and Interconnects
Hello
I'm looking recommendations for speaker cables to connect a Plinius 9200 or Hautonga integrated amplifier to PMC Fact 8 speakers. I also require balanced XLR interconnects to connect a Merdian MS600 to the Plinius amp.
Any suggestions or advice would be appreciated.
Thanks and kind regards
Clive
Clive123 said:
Hello
Clive
Hi Clive
Fwiw, i am using Plinius Odean, Hiato and Hautonga amplifiers and they are all being used with standard 500 strand OFC speaker cables. XLR interconnects to connect a Chord Electronics QBD76 DAC, Onkyo's PR-SC5508 and Audiolab's 8200CD/8200CDQ to the Plinius amplifiers are from a local Pro audio shop.
All of these cables will be more then good enough for your components 🙂
All the best
Rick @ Musicraft
Thanks for your replies.
Rick, could I ask you for your impressions on the different characteristics between the Plinius 9200 and Hautonga. The specs looks very similar.
Clive
Hi Clive
Your welcome.
The new Hautonga amplifier builds on the strengths on the 9200 by offering low frequency which is more solid, tighter and with better depth, a mid range which is clearer and more potent and a treble which is much finer and with greater extension. Added to this the presentation as a whole has more coherence, grip, speed and projects the soundstage in a more focused and natural manner 🙂
The new Hautonga amplifier was certainly worth the wait and with it Plinius are offering levels of power/performance a step closer to their mighty Hiato amplifier :bigsmile:
All the best
Rick @ Musicraft
ASI Liveline cables, if you can get your hands on them where you are. They don't look like much but they're darn good.
