Speaker cable?
I am going to be running speaker cable from Tannoy SFX 5.1 to a Onkyo 606, the QED micro cable is seeemingly good but what connections would be on the speakers, i was told i only needed crocodile clips but i am not sure if it is them or 4 mm banana plugs.
swampydrill:I am going to be running speaker cable from Tannoy SFX 5.1 to a Onkyo 606, the QED micro cable is seeemingly good but what connections would be on the speakers, i was told i only needed crocodile clips but i am not sure if it is them or 4 mm banana plugs.
My brother in law has the EFX 5.1 and has the speaker cable wrapped and clamped with the screwed caps. I don't think you can use banana plugs with these speakers.
