Sony W905a - remove intelligent core?
DjP
19
Since the weekend I'm a very happy owner of a a 46" W905a - picture is fab compared with my five year old W4000.
Here's my question: the shiny silver bit with the Sony logo on it (apparently called the intelligent core I think) protrudes down from the frame and causes me to have a gap between the TV and the soundbar (both are mounted on a stand, so if they abutted with no gap it'd look much neater). Anyone know if this does anything (apart from change colour occasionally) and if it can be safely removed? I removed a couple of nearby screws in an exploritory way, but it didn't seem to want to budge...
Looking for some advice before I invalidate my warranty and kill my new TV! 😳
Thanks!
DjP
Hi DJP
i'm glad you like your new set we have the same model and size, my advice dont remove as your likely to see a light leakage from the lightbulb thats built into the set. their for you will need a engineer to clip your bezel after fixing your fault. :shame:
Are you using the out of the box settings, i thought they were fantastic until i tweak my TV, My W9 has been a keeper ever since : Feel free to try
Cinema 1
Backlight: day:6 / night:4
Contrast: day 80 / night 90
Brightness:49
Colour:52
Hue:0
Colour temp:Warm2
Noise reduction: Off
Dot reduction: Off
Reality creation: Off
Smooth graduation - Low
Motion Flow - True cinema
Film mode - Auto
Black corrector: Off
ADV:contrast: Off
Gamma -2
Led Dynamic control - Standard
Auto light limiter:Off
Clear white:Off
Live colour - Low (Blu ray use off)
White balance R Gain -1 G Gain-5 B Gain 0 R Bias 0 G Bias add1 B Bias 0
Thanks Stuart, really useful info, will give this a try. Right now it's still sitting on comletely out of the box settings, haven't had any time to play with it yet...
DjP
