Hi there,
I would be happy if you give me some advice here. Which of the above mentioned av receivers will be a better choice for a system with dali zenzor 3 or dali Ikon 2 Mk2. I will be using the system only with 2 speakers and i will be using it both for music and movies. I will be happy if you tell me which av receiver has better sound quality.
Thanks in advance
Dali Ikon 2 Mk2Dali Ikon 2 Mk2
Thanks in advance
