Sony NW-A306
PD64
When I turn on my NW-A306 it takes up to 5 minutes before I can actually play any downloaxed tracks. I have a 1TB micoSD card installed and downloaded music is stored on it. Music has been downloaded from Tidal.
Is this just a consequence of storing music on the card?
And will it just get worse the more music I download?
The card is a Samsung Evo Select.
Odd. As far as I am aware it should play instantly.
Is this new or has it been happening for a while?
The only thing I can think of is that the device doesn't support memory cards of that size.
Many do not. Check specification or copy to a smaller volume microSD card and try that.
Et voila!
Just checked and, as I thought, you cannot use a card bigger than 2GB in your Sony so it's card size being the issue.....
Sony Walkman devices that can use SD cards support the following standards:
  • For micro SDXC cards, the Walkman supports up to 2TB.
  • For Micro SDHC cards, the Walkman supports up to 32 GB
  • For micro SDSC cards, the Walkman supports up to 2 GB.
Sony doesn't guarantee full compatibility with cards from other brands
You can thank me later for bothering to Google stuff like this as it sounds like a case of RTFM.... 🙂
And hopefully this suggestion will not get me banned as still trying to offer constructive suggestions in the only way I know how.......
