Solution to interference on Freeview?
Hello all,
Have just bought a Panny 42"PZ85 and a Sony PS3. At the moment I'm just watching Freeview with a Sagem Hard Drive box. When I try to connect my PS3 the Freeview channels experience interference on the box and the TV Freeview, lots of blocky pictures, and then when I rescan for the channels lots are missing.
So removed the PS3 and its pretty much back to normal after re-scanning for channels a number of times. So I tried even just connecting the HDMI cable (Monster M1000) just to the back of the TV and got interference from that too (without the PS3 connected).
So I know its probably just down to a poor reception, so can anyone recommend a solution? Unfortunately theres no way I can get up to the aerial, but as I say reception is good otherwise.
A booster box (which I don't know much about) or is it something to do with 'dirty power'? (just using a cheap multi connector)
Any help appreciated, thanks
I'm reminded of the man who goes to doctor and complains it hurts when he lifts his arm above his head, and the doctor says, dont lift your arm above your head then...
Since you cant watch TV and play games at the same time, why not just plug in the PS3 when your using it, and unplug it when your not?
