A admin_exported New member Aug 10, 2019 2,556 5 0 Aug 20, 2010 #1 ... that I can't find explicitly answered anywhere. Is the Freeview HD tuner backward-compatible with existing non-HD Freeview transmissions? That is, the one tuner will decode both HD and non-HD streams?
A AlmaataKZ Well-known member Jan 7, 2009 297 8 18,895 Aug 20, 2010 #2 yes, so you use them instead of SD tuners, not 'in addition to'.
A Anonymous Guest Aug 20, 2010 #3 Thanks for the very quick reply. Thought so, but preferred to double-check
A AlmaataKZ Well-known member Jan 7, 2009 297 8 18,895 Aug 20, 2010 #4 to check before is usually better than after!
