settings for ps3 , from my laptop
does anybody know how i can access the wifi security settings i have stored on my laptop ?? i want to put them on the ps3 , had them written down but cant find them ..
pc john , its the neighbours router , we share it but shes away for a while , unfortunately my laptop is being sold today , in network and sharing centre the settings are not shown , just dots , i cant get the settings again till midweek , looks like ill have to wait till then ....
Yes, you're a bit stuffed. There's a 'show characters' box on the security screen for the connection, but you can only see them when you're actually typing in the password - you can't see it retrospectively. You could navigate to the router (usually 192.168.0.1) and change its security settings (if you have the router password), but then your neighbour's going to have no internet connection when *she* gets back.
It's also possible to set up another p2p network between only your machine and the PS3 - I managed it once recently - if you're just trying to get the two to talk to each other? You might even be able to share your laptop's internet connection, but I always had terrible trouble doing that, and it will probably mean you lose your internet while you're doing it...
EDIT - actually, the latter part above is pointless, since I just read again and see the laptop's on the way out...
yeah , times are hard , lol , ill get another one soon hopefully , thanks for taking the time to help ..
JohnDuncan:You could navigate to the router (usually 192.168.0.1) and change its security settings (if you have the router password), but then your neighbour's going to have no internet connection when *she* gets back.Dont see why you would need to change any settings,and prevent internet acccess to the neighbour when she returns.
You can access the router doing as you suggested(router default U/N and P/W are easily found on net providing you know make/model and havn't been changed from default) then navigate to security settings and it will tell you current ssid and security key etc, or at least it does with my netgear router,and worked for me when i forgot its security key.
daveh75:
ta , got through to the router , this is what it shows
There should be a link or a tab somewhere on that page you got those settings from, that say's "wireless setings" or similar, if you click the tab/link there should be a box that says something like "security encryption" and the wireless key/password should be listed.
One thing though,i'd edit your last post and delete your router settings you've posted........
the links dont highlight when i put the cursor over them , ah , ill get it sorted midweek , i wonder if i will be able to post on here using the ps3 anyway ?? thanks again for the help guys ...
maxflinn:got it sorted , but the ps3 is sooooo sloooooow ....
Nice one
,dont have a PS3, but the slowness maybe this website.It's playing up ATM,or at least it is for me.
andrew , i got a one week ban message when trying to post using my ps3 , i was logged on with my laptop at the same time , trying to save settings on the ps3 , i hope ive broken no rules ? apologies for my earlier post with 3rd party info on , it was an oversight on my part ...
daveh75:maxflinn:got it sorted , but the ps3 is sooooo sloooooow ....
Nice one
cheers daveh , i think ill be in onlooker mode for a while , my laptops departure is iminent
maxflinn:andrew , i got a one week ban message when trying to post using my ps3 , i was logged on with my laptop at the same time , trying to save settings on the ps3 , i hope ive broken no rules ? apologies for my earlier post with 3rd party info on , it was an oversight on my part ...
I've got such messages before, even when not posting anything controversial. But when I refresh the page, there's no problem after that. I think it's just a problem with the website.
ah yes , it seems im not banned
,using my brothers computer , posting using a ps3 just dont work , so i better go and find a cheap second hand laptop , my god , im a cyberholic
