settings for panny 42 x10
just got panny x10,all the settings for contrast,colour,brightness are set at 50% whats the normal settings pls
Have a PZ85 but cant see it being too different:- These are my settings for you to try
Contrast 55%
Colour 40%
Brighness 50%
Sharpness two clicks
Cinema
Warm
Am at work at the mo
, but will check later tonight when I get home (not sure if brightness and colour are wrong way round)
Just checked another post about this and got my settings see below
This is how my PZ85 is setup for SD from V+ box
Picture Settings:
Cinema and Warm
Contrast just over half way
Brigtness just below half way
Colour Half way
Sharpness Two clicks left
Colour Management off
PNR off
Setup menu
IFC off
Sidepanel high
Picture overscan on
This was setup using a THX optimiser on Star wars DVD
HD
settings exactly the same except picture overscan is turned off. You
may find you prefer IFC on for HD sources such as Blu Ray (not games
console or HDTV)
Hope this helps
