Sennheiser RS220 headphones - ear pads too hot
Boeriemore
I find the ear pads make my ears hot and itchy.
Can anyone suggest a cool fabric I can cover the pads with?
BOBAD
10
I had exactly the same problem with a pair of Grado 80is and spoke to an engineer at Alessandro who suggested playing with the headband to reduce pressure on the ears.
Didn't work though so I ended up selling them and replacing them with a set of Goldring 150s which are far more comfortable and can be worn for hours on end without any problem.
Boeriemore
I know this thread is fours years old but I have not used the headphones in that time so here goes.
As the pads are made from a velvet type material, could I not glue a material that is naturally cool
over the pads? Possibly linen cloth?
Deleted member 108165
Do what you like, they're your headphones *biggrin*
