nobby44 said:Is it possible to play for example Spotify/internet radio from my PC (dell) via Wifi Airplay to a Cambridge Minx 200 or can I only send itunes files ? Thanks
John Duncan said:Bluetooth might work, but I find it slightly more faffy (pairing can disappear for no reason). However, help is at hand:
http://rogueamoeba.com/airfoil/windows/
Which works very well.
unsleepable said:John Duncan said:Bluetooth might work, but I find it slightly more faffy (pairing can disappear for no reason). However, help is at hand:
Terrible jitter, though—at least in OS X. Not really apt for hi-fi, I'm afraid.
John Duncan said:Source?
EDIT - oh and the OP has a Cambrige Minx 200, so it may not be detectable anyway.
ReValveiT said:Edit: ignore.
davedotco said:Functionally I found it excellent. I always considered a wired connector sounded better but with Spotify as a source it sounded fine.
Not using it now, I am all up to date, i7 Macbook and Mavericks. Still interesting though, any links to reliable reviews/measurements?
unsleepable said:John Duncan said:Source?
I tried with both Spotify and iTunes, and it didn't matter. Naim DAC-V1 would give an error saying that it could not reclock, and the irDac would pause and resume audio constantly.
Of course, if the DAC does not try to de-jitter the audio maybe the OP won't notice. Jitter may not only affect the pace of the audio, though. Also imaging and other qualities.
davedotco said:Interesting.
I used White Macbook>Snow Leopard>Spotify>Airfoil>AEX>dac>active speakers.
I used the AEX without a dac and with several dacs to try, settling on a cheap Fiio D3. Holding lock was never an issue.
Connecting optically from Macbook to D3 I believe the sound to be a little more 'open' and 'spacious', not improvements I find particularly important. A very slight hazyness on some acoustic music was noticeable on occasion which did not seem to happen in the wired setup, hence my preference for wired.
nobby44 said:Also "
Unfortunately, Windows 8 and 8.1 run Windows Store apps in a special sandbox mode, designed to completely isolate them from other applications. This isolation prevents Airfoil from communicating with those applications to capture their audio.
unsleepable said:davedotco said:Interesting.
While many DACs nowadays feature asynchronous USB connections, it doesn't seem so common that they apply a similar technique to de-jitter audio on S/PDIF ports. The DAC in the Airport Express, for example, doesn't. But both the V1 and the irDac attempt to de-jitter audio by using a buffer. Maybe the ones you tested also don't implement a buffer for the S/PDIF ports?
I suspect that when you connected the computer to the DAC with an optical cable you may have done it without Airfoil—as this was with the internal sound card, and therefore the default audio output of the operating system. The difference that you heard was then the jitter, and the way you describe sounds right like jitter is often described—sound is compressed, soundstage is reduced, etc.
johngw said:There are various threads on this on the internet from people with similar issues and speculation and empirical testing as to which of the AEX models is "better" from a clock sync perspective. You could always go ATV but then it also resamples to 48kHz, which is not an even multiple of 44.1kHz meaning it definitely messes with the PCM stream - each to their own if they can sleep at night knowing this! 😉 (I doubt you'll hear a difference though!)
I never noticed the issue myself having used several different AEXs into AV receivers and DacMagics and FireStone DACs. Maybe I've been lucky.
unsleepable said:Now, there have been three models: 802.11g, first-generation 802.11n (wall-plugged), and second-generation 802.11n (the current model). They all have their own internal DAC chips, which respectively are Burr-Brown PCM2705, Cirrus Logic CS4344, and Asahi Kasei AKM4430. The CS4344 and the AKM4430 are regarded to be similar in terms of audio quality, but better than the PCM2705 present in the first-generation AE.
[...] according to some reviews and user comments, jitter is really bad in the second-generation 802.11n model—model A1392, the latest model at the present. This affects both the digital and analog outputs of this model.
unsleepable said:Just to clarify what I posted about jitter, I wasn't referring to jitter introduced by the Airport Express, but by Airfoil. Without Airfoil, I haven't heard jitter with my Airport Express connected to my irDac, and I have compared that setup with my irDac directly connected to the computer through USB.
Hello,
Airfoil is fully compatible with the device, as far as the device itself is functional. Not all of our users with optical connections experiencing the issue. You can see that it isn't even constant amongst the people who experience the issue with iTunes:
(http://discussions.apple.com/thread.jspa?threadID=1877462&start=30&tstart=0).
As I mentioned, the problem is in the Airport Express units themselves, not with Airfoil. Our engineers are aware of the issue and are working on a way around the faulty hardware, but we don't have a firm date as to when it will be resolved.
Let us know if you have further questions,
