- Aug 10, 2019
- 2,556
- 5
- 0
Hi all
Just signed up to get some advice. After a good few years of not being settled. I’ve finally got a place and have dug up the hifi – which is quite old but has got me all enthused about listening to music again. However, a few things need attention.
The system is.
My options as I see it:
I’ve not really been keep abreast of changes in kit – the previous thread I mentioned seemed to imply that a new ‘budget’ priced player would likely match the Alpha 8 sonically – is this true? I don’t really know where I stand with the system as whole to be honest. I always used to try and stick to the spending equal amount on amps, source and speakers – but how does advances in technology affect that.
Musically my tastes are quite broad. Listen to a lot of electronica and techno, but also pop music (quite electronic though), some blues, punk and rock/metal (usually quite stripped down and raw stuff).
Any suggestions about the above or the system in general – much appreciated.
The system is.
- Pre-Amp: Rotel 971
- Power Amps: 2 x Rote RB960
- CDP: Arcam Alpha 8 (broken)
- Record Deck: Projekt 1.5 (I think – not great, but at the time I needed a cheap deck to listen to vinyl)
- Speakers: Tannoy Revolution 3
- Repair ~£140 – I’ve seen another thread with an 8SE where the opinion was the kit was old enough that the repair wasn’t economical sense.
- Get a DAC – OK, so this could be good. I have a fair amount of digital music now, so it could be used for a digital music source also.
- Buy a replacement
