Second system
Q Bass
36
Hi
I'm after one of those 1 box systems for the bedroom - I like the look of the Teac DRH300DAB-S it's got everything I require like DAB and USB
Is there anything else out there that I have missed - I have around £250 to spend
What I would like some help with is speakers - I have a pair of MS 906i's but I don't know if the Teac would be able to drive them
I have just enough room for the speakers so this would be ideal
Sounds good to me - shouldn't have much of a problem, they are quite sensative and the impedence isn't anything out of the norm! Yeah, go for it!
gpi
23
Is that your combined budget for the Teac and speakers? My only reservation with the MS 906i's is they are rear ported so will need some space behind them. Where are you putting the speakers? Also consider the Wharfdale Diamond 9.1 and Tannoy F1 Custom, both front ported so will more happily sit on a shelf.
Q Bass
36
Hi
I've just got enough for the system at the moment so I'm stuck with the speakers and there is some room behind them about 0.5m
gpi
23
You're welcome.
Let us know how you get on.
