- Aug 10, 2019
- 2,556
- 5
- 0
This may seem somewhat trivial, but when would you use a DAC and when would there be no need?
Now that data storage capacity is no longer an issue, I've recently been re-ripping my music using AIFF format to benefit from better quality. I have an optical audio output on my laptop, and considering severely upgrading my hifi system including a multichannel receiver.
If there is an optical input in a multi-channel receiver, would I simply be able to connect my laptop to the receiver using a an optical cable and away I go, or is the setup more complicated than that? If it is this simple, where would a DAC be beneficial?
