Samsung problems
flashgordon1952
509
64
10,970
just been offered a Samsung curved TV with a black dot on it UE7500 55 inch model for £90 is it worth the money ? as a second TV yes i know they have problems but its cheap but is it worth having
Flash, only you can decide on this. £90 isn't a lot of cash but I do appreciate that you are on a tight budget, if it's showing signs of issues already then maybe not worth the punt.
Don't see curved TV's anymore so if you needed to replace the screen on the 55" I'm sure the cost would be prohibitively expensive, assuming you can still get the parts.
