Samsung 55HU7500 review on line
ChristianCorrine
6
samsungs flat screen 4k is reviewed on HDTV test. Looks good and only a curves difference to the HU8500 in there opinion.
cheers
It's a bit daft having connections flush on the back, especially if you are going to wall mount it, i find that quite annoying and i would not purchase the tv for that reason even if i don't intend to wall mount.
I think it would be daft using scart or component on a UHD tv, not sure why they are even on there. Then again as an Apple fan I do rather like to see legacy connections being told to jog on...
Meh. If they had adapted Mini USB for video I wouldnt have minded that, but micro USB seems so dainty. The S3 and Tab3 I have seem a right faff to charge.
Regarding the S3 (and S4 for that matter) I changed over to wireless charging a long time ago.
The kit includes a wafer thin card that goes over the battery and has a tiny connector that is already in the phone.
Then plug the cable from your charger ito the small charging pad that comes with the kit.
Whenever you place the phone on the charging pad, even when it's in a cover, it beeps and begins to charge, you'll never have to plug the phone in again and save all that wear and tear on the mini usb socket.
I bought my kit from China for about £30, Google is your friend! :wave:
:doh: I think you have posted in the wrong section.
