Running DVD Recorder with CRT TV
I'm a bit of an old codger so please be patient! Just bought my first DVD recorder, a Panasonic DVD DMR EX79EB to run with my Sony Trinitron crt KD-28DL 11U tv. (The TV has Freeview built in). The instructions for set up on the recorder are: 1.Connect the aerial to the RF In of the recorder, 2. Connect the RF OUT socket of recorder to the RF IN of the TV, and 3. connect both with a Scart cable.
If I disconnect the aerial from the TV and connect it to the recorder as above the TV will not receive a signal. Also I cannot find an RF IN socket on the back of the TV so I guess it should be connected to the analogue aerial socket. I don't understand the term "RF". I was assured by the dealer from where I bought the recorder that it should run OK with my TV. Before I consult him does anyone have any advice - in plain english please? I have no immediate plans to change the TV as it runs fine .
RF socket on the back of the TV is just the aerial socket so just plug it into there as per instructions. I have this recorder so any other probs I'll try and help.
BTW welcome to the forums.
Laserman 16 thanks for your advice. It must seem really obvious to you but I have connected the aerial to the DVD and then connected the DVD RF OUT to the Digital aerial input on the back of the TV and it works. I presume the TV need not be turned on to standby to be able to record as the signal will be received via the freeview tuner in the recorder.
....but the advantage of having a tuner in your DVD Recorder is that you can record one programme and tune in and watch another on the TV.
