Rotel with Quad stand mounts
Kevin1
Thinking of matching Rotel (RA-12 in my case) with Quad speakers, for example the 11L classic? Are Rotel and Quad generally considered good partners? Any experience welcome.
I found a system of Arcam CD73T, Rotel RA01 and Quad 11L (the original ones) worked very well. Very strong on soundstaging and instrumental timbre, perhaps not the strongest in terms of dynamics.
I would imagine so., you'd have to audition for yourself.
I have the original 11L's (now in my AV set-up) and used to run them with Marantz and later Roksan amplification.
Just remember they do like a bit of power behind them on the amplification front . The Rotel should be fine.
I don't think there is anything wrong with the pairing (it could probably be bettered) but if you fancy the Quads then try to audition as it all comes down to your room and your ears. 🙂
