After the ignominious demise of my second, cheapish Sony DVD player I'm going to give up on the budget end of the market. I don't want/need a Blu-ray player so I thought of going second-hand. But I'm out of touch with the market (my original Tosh from the 90s lasted ages) so I thought it worth throwing open to the What HiFi hive mind.
I would like a machine with the following features:
- solid build
- reliable
- HDMI out
- display
- upscaling to HD (but no need to go further)
I definitely do not need wireless, apps or anything similar. I don't even need surround-sound, as I don't find it adds much. Basically, I'm after a good quality disc-spinner. If it is simple to use and serves as a good CD player, so much the better. It will be connected to a Marantz 1504.
Any models with a good reputation you can recommend?
- solid build
- reliable
- HDMI out
- display
