Rega Aethos
Gray
It's always interesting to see what's in the 'against' column of a review, in this case there were 'minor ergonomic issues'.
After listing the issues (see review), WHF's conclusion was that, 'these things are minor irritations at most'.
Sorry WHF, but if I ever pay 3 grand for an amplifier, however good it sounds, I will not be expecting any irritations.
Riri
7
looking forward to the group test on this... with RoksanBlak and Supernait 3... did my own A/B testing... for what its worth it really did come down to my preferring the Rega sound. There is something about this amp that shows you that you are getting your monies worth...
My setup is: Rega P6, Dynavector20x2l, Aria phonostage, Chord Epic interconnects/ mains/speaker cables. Buchardt S400's, Apollo CD. Node2i Streamer.
Overall I found the Aethos more engaging, richer and detailed. It sounded great at low vols, this was a big surprise as my Buchardts prefer higher vols but the detail and control at lower vols is really enjoyable and with vol up I could play at higher vols because of the control the Aethos has.
My 4ohm S400s sound incredible with the Aethos. The volume control is slightly annoying agreed, loved the Elex r volume control but hey... the ‘balance’ was notable too. Naim PRaT is better but the Aethos is no slouch... I like relaxed listening and found the SN3 a little dry and thin sounding. When it comes to Vinyl the Aethos dug out a little more detail than the SN3 and sounded richer again, fuller somehow.
To balance this out the SN3 is lighter where bass is concerned but more controlled than the Aesthos, SN3 has more grip of it but it doesn't reach the low ends that the Aethos can.
Surprisingly the Rega Apollo r sounded great with the SN3 they really complimented one another. The SN3 actually reminded me of my listening experience with the Hegel H390 which is a huge compliment because that Hegel is a cracking amp. Bang for buck I'd get more from the Aethos personally.
Soundstage was a tie but Rega edged it with depth, in another review a 'walk in' depth is quoted & I hear that. The SN3 was slightly more detailed in the highs on some tracks. Johnny Cash's Hurt for example but the Aethos gave Cash’s voice more texture, realness. The SN vocals generally are more forward sounding.
Conclusion : I loved my Elex-r and was slightly reluctant to let it go but am glad i did as the Aethos definately gives more controlled power, crispy detail and textured layer to sound that doesn't forgive crap recordings... it really does come down to 'what sound do you prefer'... I chose Rega...the SN3 just isn't as much fun to listen too.
Romulus
201
93
18,870
Thank you for your interesting thoughts. Shame on WHF of never reviewed any Hegel product to date, makes AWARDS 2020 WHF kind of incomplete and limited.
Green Bow
44
Was surprised to hear the SN3 being outgunned in the bass, by the Aethos.
No disrespect to Rega. Just that the bass of the SN3 is said to be excellent. Very fast, start stop instant, deep and very well extended.
Then with What-Hifi hinting that the Aethos is just on the lean side of neutral, I figured SN3 for richer bass. However I suppose with the Aethos being Class A, then well maybe it gets its bass from that.
I say again, I am not dissing Rega. I have the Brio (2017 model) here next to me. However I have been looking for an upgrade for some time, so ended up here. Aethos would not suit me though, so I can rule it out straight out of the gate. Not based on sound. Based on temperature and no ability to stack with it. Plus it has more wattage than I need. Plus I read that volume control is a bit blunt with the remote. Whereas I need something with smaller steps. Not Rega's fault that it isn't the amp for me; am not saying that. Just how it is.
I don't think the SN3 is for me either. I am not sure I want to start messing about with expensive power cables and expensive mains cleaners. With Naim being sensitive to mains noise. I suppose it's no harm to clean out the power supply if it is particularly bad. Just not going to go looking for problems, I think is what I mean. (Well not unless I can help it. Might end up with Naim.)
I would like to be in a position to want the Aethos though. I have weak knees when it comes to Rega.
