Recommendations on cd players?
My system consists of NAD C352,
Monitor Audio BR2
Sony XB930
Now I would like to point out that I am very happy with my hi fi but if I can achieve significantly better sound with a budget of 200.00 which of course means I would look for second hand to, then I would definitely be interested.
Thanks in advance
Hi John I am not an expert with DAC by any means but it seems to be a bigger improvement when using mp3's or lossless files, whereas most of my music is on cd and thus I am not sure how much of an improvement I would really gain from having an external DAC.
An external DAC has the potential to improve any source you throw at it, including your Sony CD player. However, using a couple of disc players into my DAC I've found that the increase in performance is not huge, if any. However, if you burn your CDs to a lossless format on your PC, and then feed *that* to a DAC, I have found the performance benefits to be large.
Of course, this requires a bit of a different mind set in how you listen to your music.....
Interesting so you are saying the budget cd player is now superfluous?
Unfortunately that presents a problem because there is no way of using a wire from my pc to my hi fi without creating an obstacle
Anyway. Even mid-range CD players are superfluous to me now, yes, because I can get a better sound from a Mac'n'DAC for £270. But it does require a certain amount of dedication and won't suit everybody.
I hope I am not upsetting no one but for £200 budget you better off keeping your current player as you wouldn't really notice any improvement even though it will be some change in overall sound.
Thaiman:
Yes!
Thaiman:
Are you referring to the external DAC? or other cd players
