receiver vs speakers
how do i tell whether speakers are too good/ too bad for the receiver i would like to buy?
receiver sony str 2400es
speakers 2005.3
this is what i have in mind but how do i know if they are suited?
Nintendo_Fan:
The 2005.3 is a bit too small and cheap for your receiver.
I disagree. You could utilise much better speakers but the Kefs will still sound good. They are definitely not too good for the amp though.
too small and cheap? is 700 pounds cheap!
ok so i take it that means the 3005 kef would be better?
i will be putting this system in a bedroom just so we are clear and dont have the room for massive floorstanders!
thehoss:
Do not take any notice of them the 2005 Kefs will be fine.
exactly, i thought it odd that if i buy the budget sony receiver 2400 that i would have to fork out for the mid range kef speakers
im sure the 2005s will be great as well!
