Question for Andrew - regarding MF 550k Superchargers
matengawhat
698
16
18,895
Just noticied on home cinema forum that you mentioned you have a pair of the above - i was just wondering what your thoughts are on these and what Amp/pre amp you use with them is it your 875 - have you got them connected using the speaker terminals to speakers terminal or line in then connected to your speakers and do you think it makes a difference which way round you do it? There seems to be some good deals on these at the moment - i would be using them for straight stereo.
Yes with the 875, yes connected to the speaker outputs, and yes I think they bring worthwhile gains, though I know they divide opinion. I think a long hard audition is the only way to decide whether they are right for you
