Quality interconnects and tape decks
Really depends how good your cassette deck is. If it's a Nakamichi Dragon, probably yes. If it's not a great deck, then probably not worth spending a lot on cables, but remember you'll need equal quality wires on the record and playback connections - assuming you're using it to make recordings, and not just play back prerecorded tapes.
[quote user="Andrew Everard"]
[/quote]
Hi, Its the last tape deck denon made for domestic use...the drm 595, one of the best about at its time, ive got around 400 cassette tapes so would spend as much on cables as i can afford as long as i know there will be a decent gain somewhere.
thanks
Chord Crimson should be fine for input and output
[/quote]
thankyou matey......sevenoaks on my dinner break is on the agenda it seems.
