quad + marantz?
alializadeh
54
hy
i heard the quad 11L classic needs a decent and powerfull amp, is this correct? will pm6004 do the job? or should i replace the amp to? with a nait 3? or marantz 1090 old schooler
Hi, I have had 11Ls for years and used a variety of amps, they all sounded good even the amp from an 80's Sanyo stacker with 'only' 20W rms per channel, so you should have no problems but as always try to get a home demo or take your amp to the dealer and listen there.
Tommo
