qed silver micro cable
Hello Simon
Yes the cable will be suitable but the speakers would benefit from a larger gauge speaker cable. This would be especially worthwhile if you are going to have longer runs (e.g., 5m+).
Hope this helps.
Best regards,
Darren
thanks darren,I have runs of about 7meters to be hiden under carpet that's why I was looking at that cable.
Hi Simon
I understand you wanting a thinner cable to help with installing under the carpet. If you can go for a slightly thicker cable (e.g., 1.75sq/mm conductors rather than 1.25sq/mm) at that length the difference should be quite significant and worthwhile. Am sure that some forum members will be able to help you out with recommendations.
You could probably run something slightly thicker around the edges of your carpet against the gripper strip if you cut away a little of the underlay thus making a channel. The cable would then sit in the channel between the gripper strip and underlay with the carpet on top.
Hope this helps.
Best regards,
Darren
If you want to use QED, I would use the Micro cable for the surrounds and thicker Silver Anniversary cable for the fronts and centre. This is very common practice. My carpet fitters just cut into the underlay with a knife and the cable slotted in.
Hi,is there much differance in size and quality between micro and silver micro,thanks.
Please could someone explain what is the difference between 1.75sq/mm and 1.25sq/mm as quote.
I second the suggestion of running Micro to the rear and surround with Silver Anniversary XT to the L+R+F seems to work really well with more weight (kinda) eminating from the front.
One thing I will say though is that stripping the ends off SA-XT is nice and easy. Stripping the ends off Silver micro is really, REALLY hard....
Hi there, i have a very simlar setup have you gone for the micro for the rear and was wondering what settings you find best for tv and what do you set your amp to for sound settings for blurays and games
regards
IMHO the general consensus of using Silver Anniversary XT for the Front and Centre speakers whilst using Silver Micro for the rears is good. However, as stated elsewhere, Silver Micro is DREADFUL to work with, the insulation is almost impossible to strip.
If you do end up purchasing Silver Micro then terminations via the dealer make sense.
peterkin101:
Except at the wall mounted end of a Kef 1005/2005 because theres no room for the banana unless you recess the wall.
peterkin101, please see House Rules, specifically No 9.
'9) Manufacturers, retailers, service providers and their staff are
required to identify themselves as such in their signature. Any
additional information - such as the telephone number, email and
website address of the company - should be put in the user's profile,
where retailers must also list all the brands they stock. 'Trade'
members of the forum failing to meet these conditions will be removed,
as will those the moderators suspect to be trade members posting under
an alias.'
simoncar:If you can go for a slightly thicker cable (e.g., 1.75sq/mm conductors rather than 1.25sq/mm) at t hat length the difference should be quite significant and worthwhile. Please could someone explain what is the difference between 1.75sq/mm and 1.25sq/mm as quote.
The figures refer to the cross section of the cable (how thick).
The larger the figure - the larger the load it can carry (house plug socket 2.5mm sq, where as a cooker 6mm sq)
Hope this helps.
thanks for that i thought it was that, but just needed confirming .
