Hi all,
I've got a PS3 Slim connected up to my STR-DN1010 which is 7.1
I don't use the PS3 for Blu-Ray (ever since the HD audio via 3D issue), so just use it for playing games.
For Blu-Ray you can obviously setup the audio to bitstream to the amp, but not for games.
I've seen an article that if I remove all PCM options in the audio settings it forces to send the signal via DTS or DD which does seem to work. If the PCMs are enabled, all game audio seems to be decoded on the PS3 and sent to the AMP via PCM.
Should this be the way I go, or should I disable the PCM options? Does this still allow for 7.1 (if there are ever games out there in 7.1 of course!).
