Hi all,
In the May issue, I read about the PowerLine network via existing power cable around the house. Does this work in any type of house or any type of power cabling ie. Will it work in Malaysia for instant?
If yes, which model would you recommend. Requirement is quite simple:
1. My wifi router is in the living hall downstairs
2. I need an 2 ethernet cables for the upper floor because the wifi signal is not strong enough. Need one for my laptop in my hifi room and the other one is for my LED TV both on the upper floor.
Can the PowerLine be used via an extension cable ie: a Belkin 8 way extension? Or it needs to be plugged direct to the wall socket?
Appreciate any feedback.
