daspaceman:
MattSPL:Id suggest a used Krell Kav300i, 300iL or 400xi(£700-1200). These are all intergrated amps but have a function for Av use where you can just use its power amp section like a regular power amp for your front left and right speakers. Then for purely music, you can have your cd player hooked upto the Krell and achieve a much better stereo sound as opposed to using a surround processor for the job.
Thanks Matt, but isnt a seperate power amp and an av/preamp better than an integrated? Rotel`s preamp is very neutral, I think a power amp connected to it is a better option. What do others think?
I would think that the Krell's pre amp would better all but the most expensive Av pre/processors but i could be wrong.
Some say that a well designed intergrated will beat any pre power combo due to its simplicity and lack of interconnecting cables.
I believe the Krell FBI intergrated, fed via cast cables from a krell cd source is pretty much as good as it gets. Expensive though.
See what others have to say as i dont know anything about Av really.
