- Aug 10, 2019
- 2,556
- 5
- 0
Hi Guys,
I have had a brief search through the forum and have not seen any posts on this topic, but if I've missed something let me know.
I really need help dealing with a problem I am having with my Sony 5300ES receiver. I use a PS3 as a blu-ray player and therefore have to send all HD audio as a decoded LPCM stream. The trouble is that my 5300ES makes a very audible hiss when receiving a LPCM signal. This hiss becomes audible from my seating position at anything above -15dB and increases in level as the volume climbs.
This hiss is even audible in the XMB. Some Blu-ray movies require a volume level above -10dB and under these conditions the hiss competes with dialogue. Switching to a bitstream output produces a hiss-free sound, but limits me to standard DD and DTS. Sony have even suggested this as a "solution", but I only upgraded from my Denon 1905 to gain HD playback capability!
I have posted this here to ask owners of new Sony ES receivers, who also use a PS3 for BD playback, to please check if this is a problem you also have. In order to check simply set the PS3 to output LPCM over HDMI, with all bitrates enabled. If you have this problem then the hiss will be present on the XMB as you raise the volume level above -15 to -10dB (depending on your speaker sensitivity). The Sony technician tells me that he has tried this on multiple models and has heard the hiss on all of them. I suspect he is trying to put the blame on the PS3 however - Sony South Africa do not distribute the PS3 in South Africa, so this would relieve them from responsibility.
Finally, for the What Hi-Fi team, I see you have posted a very positive review on the 5400ES. If you still have that unit, could you please check if it also suffers from this fault?
Any help would be greatly appreciated!
