plasma tv in conservatory
Hi,I am getting a new tv for the conservatory(see other post),now in my lounge I have a panasonic 42 inch v10,which I am very happy with.
now I have been looking for a new tv for the conservatory,but now I am thinking should I put the v10 in conservatory and get a new tv for the loung,the only thing is should I be putting a plasma in conservatory with the differences of temperature and glair.
I have a large south facing conservatory and it gets extremely hot, even with AC in there. I went for an 32" LCD in the end and it copes with the heat and reflections without issue. And it's White so the aesthetics look bang on too.
Thanks Mark for your opionions on the lcd,I already have a lcd in conservatory.
Have you ever had a plasma in your conservatory.
I did try my old plasma from the lounge a pioneer 507XD and it was pretty much unwatchable, I had to use the vivid setting when the sun was out. The reflections really bounced off the screen ( our conservatory is a P shape) from all angles. Newer sets with reflection filters may cope better. Hope this helps.
Thanks mark,I am thinking of putting my v10 in conservatoy and getting a new vt30 for the lounge.
The other thing I did notice was the glass screen got amazingly hot ( does not happen with my LCD) and my 2nd old actually burnt her hand on it slightly, maybe should have mentioned that earlier.
Thanks,I have not got that problem my kids are 8 and 12,I just dont want to ruin my plasma.
I'm using the plasma in my bedroom now and there are certainly no visible problems and the set was in there all last summer.
Thanks,perhaps there may be a bit of tv movement on the weekend to try,thanks.
