SC:
Damien, have you read if it's just the monitors that have the buzzing issue, or the TV models as well...?
I found the 428XG here in a store, no problem, which is cool as I think you just can't get them in the UK now.....But then, I got to thinking about the 50" monitor ! I don't know if you can get them here, will have to check, but I wouldn't need or want the TV model, and I prefer the clean lines of the monitor panels....Will have to check it all out, as a fair bit of my use will be SD,ÿparticularlyÿTV broadcasts here, and the 50" may be too much and a waste...?
I can't remember from the other thread, but how much cheaper did you get the 60" monitor over the TV model - is there a big difference ?ÿ
From what I've read (and I've read a lot in the past 2 weeks) its pretty much ALL plasma's (from all brands) which can and do have this problem to some degree and Pioneer, due to their unique method of (waffle / 2 pieces glass rather than 3) construction, seem to be more of a culprit than other brands. That is of course offset by the unmatched superiority in picture quality - and in my opinion, there is no comparison. I looked at a LOT of sets before buying the KRP-600M and nothing came close. If you're in the market for a plasma, definitely take a look at the monitors, the picture is awesome. I had the boys round for a pile of BluRays over the weekend and its unbelievable.
I've no idea what price the standard sets cost as they won't be available in Australia until early next year - hence why i opted for the monitor - its the only 9G Pioneer panel available this year in Aus. I believe from what I've read elsewhere that the monitors are approx. the same price as the integrated sets but marginally superior in PQ and have far more calibration options etc (they can have multiple ISF presets calibrated) and are 65mm thick rather than 90mm.
The store model I auditioned was silent beyond 1ft from the screen so I believe my issue is a batch problem so don't be put off. From the service I've received from Pioneer and the store, i am confident I will get this problem resolved - or at least I hope so anyway. Pioneer will be bringing the shop model to my house this week to compare and if I'm happy with that, I'll be keeping that one. Stay tuned if you're concerned - I'll tell it like it is. One thing I would suggest is if you're dragging a set home any distance (which I think you are?), get the dealer to set it up for you and turn everything else off so you can check for buzz before you head home.
Some other forums I read on this issue:
http://www.avsforum.com/avs-vb/showthread.php?t=945491
http://www.audioreview.com/PIONEERPLASMAcrx.aspx
http://www.dtvforum.info/index.php?s=59c9000b19eab8b85f7fd3b7eccd53de&showtopic=23805&st=40&p=1042021&#entry1042021
http://www.highdefforum.com/archive/t-5733.html
There's even a forum thread and poll on the Pioneer 9G buzzing here:- http://www.avsforum.com/avs-vb/showthread.php?t=1044254&page=4
