Pioneer VSX-920
Help, I was looking at the above and the review says it doesnt have an audio return channel, 3D is a must as I plan to get 3DTV and projector in the future, is there an issue with 3D and audio with this amp.
It's not the end of the world. It just means you'll need either an optical or an analogue cable running from the TV back to the amp - only if you use the TV's built in FreeView or FreeSat channels of course...the 3D video and audio works fine.
Think I'll just go for onkyo 608, will be using with proj and TV, that reminds me, needs 2 outs aswell.
If you want two HDMI outputs, you'd be looking more towards the £700 mark, unless you're looking at outgoing models, with which you can use a dual HDMI output Bluray player to get HD audio and video.
