- Nov 22, 2008
- 19
- 0
- 0
I've Just got myself a couple of the Tacima mains conditioners to plug all my Hifi and AV stuff into and came across something unexpected...
Firstly I have plugged my Musical Fidelity Amps and CD player into the Tacima and have been, as have others, most impressed by the results. All seems to sound better...instruments and voice sound better seperated etc.
Anyway the hifi gear is going into to one of the Tacima's which goes into it's own mains socket in the wall.
The other tacima is connected to another mains wall socket and has my Blu-Ray player, Yamaha AV amp, SKY HD box...and my Pioneer 5090 plasma. (well it's not now as you'll see below..)
All 'works' ok..BUT...when I want to listen to a source into my Yamaha AV amp, SKY, Blu-Ray etc.. I set my Musical Fidelity amp source to the Aux input that is connected to the Yamaha amp and set the volume control to 12 o'clock...all pretty standard stuff...the Musical Fidelity powers the front L/R speakers...the Yamaha does the other speakers.
The problem that has only happened since the Tacima's is that when I turn the Plasma on I get some fuzzy 'noise' from my front speakers. More than just the normal hiss that you hear when your ears up close to them (due to the volume being up to 12 o'clock point). A slight buzzing noise is there too. At this point i've not got the SKY box turned on or anything actually sending audio..otherwise i'd probably not hear it...but I don't like the fact that it's there. Definitely not right. If I turn the plasma off onto standby It goes away, and if I unplug the plasma from the Tacima and run it from its own wall socket I don't get the noise when it's on either...which is how it's always been.
Strange huh! I wonder why the Plasma is introducing noise into the system if plugged into one of the Tacima's with everything else? Maybe it's overloading the Tacima. If I had a third one I'd of tried the plasma in it on it's own and seen if it still causes the noise through the speakers.
The plasma's power cable by the way is a 2m Clearer Audio Copper-line Alpha.
Anyone?
Anyone?
