Pioneer LX 72 Speaker Advice
Have just purchase a Pioneer LX72 Receiver /LX52 Blu Ray Player and was looking for advice as to what would be the most suited speaker package/combination to partner this receiver.
any advice welcome
Movies and Music probably in that order depending on my mood so speakers would have to competent with both.My sound type preference would probably be a neutral sound with bass being highlighted (if that makes sense) and as for room size unfortunatley room dimensions are only 5m x 3.5m with my normal sitting position being about 4m from screen/front speakers.
Thanks for reply
Sounds perfect for the B&W MT30 or the M&K 7 speaker packages.
The Dali Lektor range will give you the bass and works very well with Pioneer in our experience. The Tannoy Highline 500 or Revolution Signatures will give you a bit more detail and excel with the Pioneer SC range.
