D DJEPSON New member Jul 29, 2009 73 0 0 Sep 18, 2009 #1 I am in the Channel Islands so limited options with TV buying. 1 shop has the KRP500 the other the LX5080D (I assume the 8th generation), but both for the same price £2,400, are they value for money ? Thanks in advance Damian
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 Sep 18, 2009 #2 508? You don't mean the 5090? In that case NO it's not value for money, the 5080 is a generation out of date! Even the 5090 should be a couple of hundred quid cheaper than the KRP-500a, so if you can get the 500, do it!
D DJEPSON New member Jul 29, 2009 73 0 0 Sep 18, 2009 #3 No it it is the 5080, these are the joys of living on a small island and they should be cheaper than the UK becuase we dont pay VAT
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 Sep 18, 2009 #4 Crikey, avoid the 5080 then, get the 500 ASAP. No VAT? Yes that should be a lot cheaper, 2,400 is more than I paid for my 500a!
A Anonymous Guest Sep 18, 2009 #5 Stop reading this immediately and go and buy the 500A now. It must be the only one left in Europe. Get it before it goes. You wont regret it.
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 Sep 18, 2009 #7 barnsleydave:Stop reading this immediately and go and buy the 500A now. It must be the only one left in Europe. Not far off I'd guess! Get it before it goes. You wont regret it. What he said...
